Possibly because when you insert one end of the bulb in its socket there can be a high voltage exposure at the pin(s) of the unconnected end.NEC 410.130(G)(1): Does anyone knows why NEC requires disconnect means for lights with double-ended fluorescent lamp but not other type?
If you hold one end and insert the other you can get zapped.
I think its more for ballast replacement safety.
Maintenance men working them hot and getting hammered from grabbing a hot or neutral.
I have always though that it was because on the single pin lamps removing the lamp diconnects power to the ballast where as on a double pin the ballast gets power directly from the source.
That, however, is based on my antique knowledge of fixtures. Old men don;t climb ladders and change ballasts so things might have changed![]()
That's interesting. I never knew removing a single pin lamp removed power from the ballast. So by double ended, they don't mean lamps that connect on both ends, they mean lamps that have 2 pins on each end?
That sounds like a plausible explanation. Maintenance people who have worked on single pin lamps may not realize removing a double pin lamp doesn't remove power to the ballast.
I don't replace ballasts either, but I can confirm on most double ended lamp fixtures, power goes straight to the ballast.
Someone else please, but I think your original impression of a double end lamp is correct. The speculation that the disconnect has anything to do with lamp change is false. You have to remove lamps to remove the cover to access the disconnect. It is there to facilitate changing the ballast only.
