hvacmonster
New member
- PA
I am working on a project at a school where we are replacing Self-Contained Unit Ventilators (they have hermetic compressors in them). There are multiple units fed from a single circuit so the breaker in the branch panel is larger than the unit nameplate for Maximum Overcurrent Protection since its feed multiple units. Each unit has a non-fused disconnect switch and all branch circuits withing the unit are fused. So the branch circuits for the fan, compressor and low-voltage components are all protected by fuses. One of the electricians is stating that NEC 440.4 requires fused disconnects at each unit since there are multiple units being fed from one circuit. Its too late to add them to the units since the equipment is onsite and the cost to add them now is large. If the code requires them then we'll have to add them but the unit manufacturer is stating they do not believe they are required when reading the code. I am not sure what to do so just looking for some expertise or direction on where to find my answer.
Thanks!
Thanks!
