NEC 680.26 (B)(1)
codequestion
Banned
MD, USA
NEC 680.26(B)(1)(a) says unencapsulated structure shall be bonded together by steel tie. Where structural reinforcing steel is encapsulated a copper conductor grid shall be used.
I have pool made out of concerte. What does term unencapsulated and encapsulated mean? Examples of encapsulated material is what for pools.
Sent from my SM-G935U using Tapatalk
Encapsulate in this instance means that the steel (rebar) in the concrete is covered in a non conductive material----
so the steel (rebar) isn't in direct contact with the concrete, which is why the cu grid gets put in.
What are some products that would make steel (rebar) in concrete a non conductive material when covered with the product for pool?
Epoxy-----they coat the rebar with it to discourage corrosion/deterioration of the steel.
