jaggedben
- Northern California
- Solar and Energy Storage Installer
I've been assuming in this "carport array" that there is no roof underneath the solar panels, and the solar panels are the only "roof". If that's the case, you don't have a carport after removing the panels, you just have some columns and some beams.
If you do have a roof under the panels, then I agree it's a carport, and none of that carport is the array support structure, same as case (3).
Any solar carport could have the solar panels removed and replaced with a different material that makes it just a carport, and often vice versa. And there is nothing in the definition of an array that references having a roof under the modules or not. So if you're going to contend that using solar panels on top of a carport necessarily turns the entire carport structure into an array, then putting solar panels on the roof of an enclosed building - especially using BIPV methods - would also necessarily turn the entire building into an array. But this is an unreasonable outcome, and the mere phrase 'with a support structure' doesn't require you to do this. Nothing in the definition precludes you from distinguishing 'support structure' particular to the array from other support structure, or even the array itself from the support structure so long as it's 'with' one.
A reasonable interpretation (and some sort of interpretation is required) might be that support structure is part of the array if it could serve only the purpose of supporting modules. Then a carport structure that is capable of supporting other material that could provide shade needn't be considered part of the array.
