wbwald
- Norcross, Georgia, USA
I am trying to determine if my interpretation of NEC Article 110.26(C)(3) is correct or where i am misguided.
I am designing an electrical room with a 4000 amp, 3 phase, 4 wire, 480Y/277V busway with (2) 400 amp busway disconnects, (2) 400 amp panels that feed 112.5KVA transformers that feed (2) 350 amp main breaker panelboards. This situation is typical for most of the tenant floors for a high rise office building. I have the code required clearances for all the equipment. My question is whether the door for the electrical room is required to swing out of the room and whether the door is required to have panic hardware? my initial interpretation is that the door has to swing out and have panic hardware?
