iwire said:
David the person who installs it or supplies it is not the issue, it is who ultimately controls it, as in which side of the service point the specific item is located.
Defining "control" is more than just tricky, it's nearly impossible to get a definition that all parties agree upon.
We have a power company in our county that has no involvement with the service past the drip loop and yet if the meter on the building is installed outside of a highth range of 3 to 5 feet, they refuse to power the meter. . Does that mean they "control" the meter ? . They also require a "heart" loop installation in the meterbase. . That is a controlling requirement.
How can you possibly define "control" ? . At least the code is a little more specific by saying "exclusive control". . But even exclusive control isn't completely clear. . The overhead conductors that the power company themselves install are definitely "exclusive control". . But how about the insulator that the contractor buys and installs himself ? . How about the mast and meterbase, contractor bought and installed ? . How about the main disconnect ? . Where does "exclusive control" end ?
iwire said:
In many areas the EC installs the service lateral even though the service point is typically at the meter.
If the contractor is buying and installing the mast, what determines that the service point is at the meter ? . Are you referring to a statement by the power company ?
iwire said:
IMO it secures the utility controlled conductors and has nothing to do with the customer owned riser.
What is the difference between a "customer owned riser" and a "service point is typically at the meter" which would extend the power company control all the way to the meter ?
If the customer bought and paid a contractor to install the riser isn't it a "customer owed riser" ? . And yet you said:
I'm sticking with my question to joesparky:
Where did you get the lag bolt insulator ?
If he answers, I got it from my supply house, then I haven?t changed my mind about what I?ve posted so far.
If he answers, I got it from the power company, then I?ll agree with your conclusion.
David
