brother
Running into more controversy over the energy code in my area. Lately more and more people/work stations are asking for the switched receptacles to be constantly energized because of their work, even if we suggested adding more occupancy sensors to reduce the chance of it happening
I told them I have to get approval from others because last time we did this in other areas to keep people happy we got a 'good lecture' from the powers that be that we shouldn't be doing this, without prior approval because of energy code requirements of having the 50% of receptacles being switched.
So the question is, has your area run into this issue with the customers and energy code adoption? also when you make the receptacles constantly hot do you change out the receptacles to regular ones since the switched ones had the switched symbol on them? I was informed it was a code violation to have a switched symbol receptacle remain and it was no longer switched. What NEC code article is this one found?, I don't have my code at the moment.
I also noticed that the receptacles were split with 2 circuits, (one switched the other one not) but they did not use handle ties or a 2 pole breaker for the circuits, another violation. It gets complicated when the circuits are not side by side.
