mark32
- Currently in NJ
Hello all,
A new customer has asked me to repair her deteriorating step lights. This is the light: https://www.amazon.com/Hadco-Lighting-RSC2-H-K5-I-Voltage-Aluminum/dp/B01BFWPLKU
You'll notice there is a screw in each corner, this screw holds the face plate to it's housing. Some screws are removable, but most are frozen to the housing because of major corrosion/oxidation. It's medium based socket was originally fastened to the housing but now the socket is just floating about. The only thing I could come up with is drill the heads off the screws and then hopefully find a slightly larger face plate and anchor that directly to the surrounding brick. Any ideas? Thanks!
