Use a wire sock, they are worth the money in the long run. Also we use the clear lube. It seems to work well and cleans up really nice. Those pulls should not be much at all. You do need a few hands for a day or so. As far as a tugger I bet the Maxis 3000lb would work.
We have several projects right now that have 500 and 600 kcmil pulls of over 400 ft. We have an Ultra Cable Feeder for the reels and the right reel stands. The best advice I have is prepare well. Do not try to cut corners. If there is a way to screw up a wire pull it will happen. Keep all the debris away from the reels. Make sure the pipe is clean because if there is a rock in it you are in for a bad day. Good luck, David
