Strombea
- Prescott, Arizona, USA
We are remodeling an old motel and changing to 30 studio apartments. I Have never worked on anything with more than a 4 pack meter stack, so i want to get as much info as possible.
POCO will supply 2 or 3 separate meter stacks with 800 amps per, or so, - I haven't done calcs yet.
I will have to go underground after metering point to other isolated units in different buildings (probably around 8) because POCO will only allow me 2 metering points but there are 5 separate buildings.
So the question is on multi family dwellings can i share a 4" pipe to a building with 4 sub feeds from meters in it, and upsize and share a neutral between units as to have l quantity of wires in the pipe? does each studio need its own conduit? Does it need to be metal out of the ground? Where do you change from independent wire to romex-type feed wire or do I run pipe into each unit's panel all the way from the meter?
Imagine all the meters divided up mounted on 2 buildings but there are more units in separate buildings that i need to feed from meter on a different building.
Who is the best manufacturer for the meter stacks and distribution cabinets?
I do alot of residential and commercial but nothing ever with this many feeds.
Thanks guys!
BTW motel used to be house metered so the new owners obviously want individual meters.
Thanks guys!
