My company is Thermal Interrupt devices and we have a patented design for a device that prevents centrifugal pumps from overheating due to loss of prime or blocked intake/discharge piping. The device is screwed into the pump housing with 1/4" MPT and wired into one of the hot leads of the pump motor. Typical applications are swimming pool pumps, spa pumps, above ground irrigation pumps, de-watering pumps and various types of submersible pumps. We have several designs for different applications from 110 v up to 240 v 3-phase.
When the device detects a pump temperature of 120 F, the electrical contacts open and power is interrupted to the pump motor, thereby saving the pump from destruction due to overheating. The device must be reset either manually or remotely by a technician or by a knowledgeable homeowner. The device is not to be used or considered as a normal on/off switch and the warning label states that the main power to the motor be disconnected before attempting to reset the device.
The device is water resistant, mostly plastic with no conductive material connecting the internal electrical contacts with the metal threaded base. The electrical contacts are approximately 1.5" away from the threaded metal base and are contained in a separate, non-conductive housing to which the 14 AWG leads are attached and are lead out of the device through waterproof fittings.
Now for my questions (finally!):
1. Will this device require a ground wire? If so, why?
2. For 240 v applications will we have to break both hot leads or can we just break one? Again, this device is not intended to be a fuse, breaker or normal on/off switch.
Thanks in advance!
[/LIST]
Thanks in advance!
[/LIST]
