bullheimer
- WA
This Mixing room is attached to, and came from, a premanufactured automotive paint booth. All my owner keeps saying is that it has to be explosion proof. i am not even sure what catagory it is. i guess i need to read up. There is a continuously running 24/7 exhaust fan in the ceiling that's pretty big. I have to run power into this room for the mixer motor thru the ceiling and the fire supression guy just drills a hole and puts a standard looking grommet around his pipe and leaves. I am wondering how that is Kosher. I have to run a pipe down to the motor and then liquidtite into it, which i guess is all good. But i am wondering how a circuit card for the display board can have it's back be open and be called intrinsically safe?
Also there is a scale to weigh the paint that has a cord on it that is supposed to be run outside the room to plug into an outlet.
I have never had to wire up anything like this before. It has double metal wall panels. A control panel has a cable with a plug in connection that attaches to the inside wall. Nothing has any place to pour powder or put putty. any help as to what type of catagory of hazardous location this is, or what is normally done with these kinds of rooms would be a great help. Are there substances to put into the ends of liquid tite like duct seal, or does there have to be an explosion proof fitting going into the motor first, i'm just not up on this paint booth stuff. if it was a commercial garage, theres a 3 ft up from the floor explosion proof requirement, that i think goes away with continuous ventilation. i don't think that applies to this room tho. the motor and scale both are going to be within 3 ft of the floor anyway.
