mkgrady
- Massachusetts
A customer has a heat relay that is stuck in the on position so it must be changed. It is a Minivector model 50240. It has an internal 24 volt control transformer with built-in power and control wire leads. It is connected at the electric panel through a knockout except for the thermostat wire connection.
I look at the power wire leads and find wires connected to two 240 volt heat circuits and find the contacts are meant for two heat circuits. I did not bother to sort out how the circuitry functions thinking I would just buy a direct replacement and hook it up the same way as the old one.
There are two problems. I am unable to find a replacement relay and I can't figure out what the contacts do in the relay. I find the connection diagram unhelpful. Does any body know of a direct replacement for this relay? Except for the self contained control relay which I can provide seperately, is this a simple DPST relay? I do have a picture of the connection diagram but I don't know how to post it.
