That’s what we doHow often is it trued up, or does the meter just register kWh at one rate forward and the other backward in real time?
Yes, your right..I think most met metering laws are at the state level![]()
It's more like $.30-$.50 per kWh if you are going to maintain a grid connection for high demand, i.e. install non-export system where you don't count upon getting paid anything for exporting. That's if there are no unfair penalties for doing so.If you are willing to pay $1.00 per kWh I guess you could do that.
Correct.Terminology:
Net metering means an arrangement where exports to the utility are credited at something based on, but not necessarily equal to, the retail rate for imports.
'Net billing' is a term that means any credit for exports is based on something other than the retail rate, such as a prevailing wholesale rate or a special value of exports rate.
In my experience both tend to get lumped under 'net metering' when people are not meaning to be specific. However, in the thread above, HvLv is using 'we don't allow met metering' in the specific sense, because they do allow net billing. Whereas the coops mentioned as not allowing solar at all are not allowing either. BTW the latter may be a violation of the 1978 federal PURPA act.
I'm confused. So avoided wholesale is twice retail during peak hours?We pay avoided wholesale rate to all exported power through one meter. Use all you produce and sell excess at the price we pay other providers. We pay TWICE RETAIL rate for anything produced during peak hours.
No. Wholesale is just that. And we pay wholesale rate during export. Except at “peak hours”.I'm confused. So avoided wholesale is twice retail during peak hours?![]()
I was wondering about NEM in other states. I am in CA and we are going through a fight to try and keep it to some level.
I heard Florida just passed a bill that changed the NEM there. Does anybody know in Florida what it is now- the credited amount you receive as a homeowner when your excess solar goes back to the grid?
Didn't Texas do a similar thing?
I know in Arizona solar was hot until the utility companies put a kibosh to NEM.
Anybody here solar contractors in these areas? If so, is solar still going strong?
Is storage being implemented to help grid and solar consumption?
Sent from my SM-G998U using Tapatalk
Yes. Even if a residential PV system isn't exporting, i.e., its entire output is being consumed by the homeowner, the demand from the grid is reduced by that amount.So if the utility often times pay higher than retail costs for electricity during peak hours wouldn't solar be beneficial to the utility, at least during those peak hours? In CA the peak hours are around the time solar is generating a lot, especially if the array is facing more west.
Hv, I forget where You are located,is there lots of air conditioning in your region? Up here in the Northeast, there isn't much air conditioning and I am thinking in general most people are exporting during peak hours.No. Wholesale is just that. And we pay wholesale rate during export. Except at “peak hours”.
During peak hours we pay a premium for any electricity exported because it helps us offset the ridiculously high priced peaking power.
Unfortunately not many can or will export during peak hours because they are using everything they are producing.
Lots in summer.Hv, I forget where You are located,is there lots of air conditioning in your region? Up here in the Northeast, there isn't much air conditioning and I am thinking in general most people are exporting during peak hours.
I have a relatively large 16 KW system, which is net metered. My house is half finished and I don't have all the modern conveniences so I end up with almost 4000 KW hours surplus each year. So even with that metering, seems like this isn't a bad deal for my utility.
Yes, I wasn't referring to anything you mentioned....
It isn’t a violation of PURPA.
As much as I despise net metering, I think there is a place for solar.Yes, I wasn't referring to anything you mentioned.
What would be a violation of PURPA is outright banning customer self-generation and refusing to have any program that allows it or compensates for exports to the grid.
Yeah, in real-time. There is no NEM at all. You are correct about the batteries. It undercuts the whole idea of rooftop PV helping to support the grid. They are saying keep it all for yourself.In real time? That is, do you mean that if you export a kWh they credit you for it immediately at the lower rate and then charge you the higher rate when you draw it back out? If so, that's a case for installing batteries.
Most of the NEM programs I know are run by each utility. They might be following the directives of a state or local utility commission outlining some of the requirements of a NEM program. For instance, the big 3 IOUs in CA are under the CPUC which directs their operation as monopolies. But the municipal utilities are under the oversight of local public utility commissions. In CA it required an act of the state government to force local municipal utilities to offer any kind of NEM and that has run out. So now we have municipal utilities that are just ending NEM although they still have to allow PV systems to interconnect and they have to pay at least the avoided rate for energy export.I think most met metering laws are at the state level![]()
Hv- so your a utility guy (some of my relatives are as well- lineman). Is this what you think is fair all the way around (for solar homeowners & commercial owners and the utility company)?We do allow Net billing.
And I believe it is fair to all.
