james_mcquade
Hi everyone,
i am at odds with one of my customers over the use of prox switches in the following situation.
from the plc inputs, we have standard 24 volt prox switches ( rated ip67 / Nema 4) detecting metal cans filled with areosol paint/other chemicals.
last week, one of these cans tipped over and destroyed (1) of these prox
switches resulting in the electronics being exposed.
i argued with the customer that the prox switches were not safe and could have ruptured the can that turned over due to the confined area and thus cause a fire / explosion.
he didn't seem to care because the switches are rated Nema 4.
i explained to him that the Nema / IP rating of a switch is to let the user
know what the sensors outer case will protect the electronics against: dust, oil,water, ice.
i went on to explain that the electronics of the 24 volt prox was not intrensically safe because you had 24 volts and how ever many milliamps/
amps of power the circuit was fused at powering the device. i also stated that intrensically safe sensors were designed in such a way that if the sensor was destroyed, the electrical potential of the device would not have enough energy to ignite the paint.
he stated that he would get his safety department to address my concern.
did i miss something or am i making a mountain out of a mole hill?
there are 10 people that will be in the line of fire if one of these cans are
ignited due to these prox switches.
thanks in advance,
james
thanks in advance,
james
