Mike Hughson
I have a client that is demanding we use Nest smoke/carbon detectors. Anybody know how many units can be used together, or any experience with using them. Thanks for your input.
If the NEST front end supervises the detectors so that if one fails or goes off line for some reason it lets you know, that number goes up to 64, of which 42 can be smoke detectors. NFPA 72 (2016) 29.8.2.2.(3)I believe its 18.
They need to be activated before they are installed. You need to scan a QR code on the back or enter the ID number into the app. You will need active WiFi for initial activation.
If I supply the units I will frequently just hand them to the homeowner and have them pull the battery tab's, activate, remove the batteries and label the boxes where each unit goes. If the customer supplies I tell them to activate before giving to me. If the customer wants you to activate they will need to set up a Nest account, if they don't already have one then give you their login info. Do NOT set up your own nest account and activate or the devices will be associated to you instead of the customer.
The devices communicate between each other over wireless communication (not WiFi). WiFi is only required to set up and alerts. They do not use the 3rd interconnect wire. You can mix 120 volt and battery only models.
That's a start. Use you imagination from there on what you could do next.I'm not seeing what the advantage is in using these sd's. So, if you're on vacation in the Bahamas and your smoke alarm goes off, you get a notification on your smart phone that your house is on fire ?
If the NEST system meets the requirements for supervising the connected devices, you can use more than 12 smoke detectors in your home. Some places are so large that you need more than 12, and previously the only way to do that was to install a full-blown fire alarm panel.I'm not seeing what the advantage is in using these sd's. So, if you're on vacation in the Bahamas and your smoke alarm goes off, you get a notification on your smart phone that your house is on fire ?
Stay in the BahamasThat's a start. Use you imagination from there on what you could do next.
Well it would allow you to be miserable from the moment your house is burning instead of finding out later.I'm not seeing what the advantage is in using these sd's. So, if you're on vacation in the Bahamas and your smoke alarm goes off, you get a notification on your smart phone that your house is on fire ?
Roger
Yes, but in that case you might want to extend your vacation a bit.I'm not seeing what the advantage is in using these sd's. So, if you're on vacation in the Bahamas and your smoke alarm goes off, you get a notification on your smart phone that your house is on fire ?
That can be done but I'm not willing to install non activated smoke alarms. They either need to be pre-activated or activated as installed. If you simply install the devices and give the customer the ID numbers you have no control if they ever get activated. The alarms will work independently but will not communicate until activated.I've installed them for a few of my customers. They don't need to be activated before you install them (it is much simpler if you do though) as long as you have recorded where each on is located (I would write it on the box it came out of, it has the serial number on it.
I then give it to the customer to activate.
I am right now working on a fire job that the owner had one of these installed.
He just left the house an hour prior and all of a sudden he gets a notification on his phone, he immediately contacts the fire department and they got there before the fire even breached the room. ( not so much for the smoke damage though )
I was impressed though.
curt swartz said:That can be done but I'm not willing to install non activated smoke alarms. They either need to be pre-activated or activated as installed. If you simply install the devices and give the customer the ID numbers you have no control if they ever get activated. The alarms will work independently but will not communicate until activated.
That's good practice.That can be done but I'm not willing to install non activated smoke alarms. They either need to be pre-activated or activated as installed. If you simply install the devices and give the customer the ID numbers you have no control if they ever get activated. The alarms will work independently but will not communicate until activated.
What would have happened if he was in an area at that time where he had no cell signal? Don't you think the money would have been better spent on a monitored system?
Very good point. By law we are supposed to install smoke alarms which means that they have to be operational when we leave. I assume that there is going to be liability on your part if you hand them over to the customer, there is a fire and the customer says that they never got around to activating them.
I think if it were my customer that insisted on Nest, I would be forced to install conventional wired alarms, then put the Nests next to them. Either that, or tell him that he can go around himself and replace my alarms with the Nests after he gets the C of O.
If the customer rebels, just tell them that that's what you get for using techi DIY garbage. I'm not putting my license and livelihood on the line so you have a toy to play with.
-Hal
With that said, they technically should have passed some sort of certification process to prove they are reliable before being released into the open market... no?
Very good point
I totally understand the paranoid of being sued aspect to your concerns.What would have happened if he was in an area at that time where he had no cell signal? Don't you think the money would have been better spent on a monitored system?
-Hal
