As @tthh says above, there are plenty of other programmable thermostats besides Nest and Ecobee. Seems that Nest and Ecobee make wild claims about saving energy in their ads so that's what people ask for. Honeywell (who you'll probably never see an ad for) has any thermostat you could ever want, and they work with all heating and cooling systems because that's what Honeywell was founded on. Not some techi toy company.I have a customer who wants Nest thermostats or some other "smart" controls.
Honeywell spun off their residential thermostat business several years ago, creating a techi toy company called “Residio.” My daughter had a Honeywell that would no longer do scheduling properly once Residio took over the software. Replaced it with a Nest that works perfectly.As @tthh says above, there are plenty of other programmable thermostats besides Nest and Ecobee. Seems that Nest and Ecobee make wild claims about saving energy in their ads so that's what people ask for. Honeywell (who you'll probably never see an ad for) has any thermostat you could ever want, and they work with all heating and cooling systems because that's what Honeywell was founded on. Not some techi toy company.
I just happened to watch this video last night. Shows what you get into with those things.
-Hal
When she says "smart", what does she want it to be smart about?Thank you. I do not think she is attached to Nest. So The recommendations for the others are helpful.
I was going to mention that Honeywell Home is now Residio. I wouldn't call them a techi-toy company. Alot of the Honeywell commercial line was rebranded Honeywell Home before Residio. ("Home" made no sense.)Honeywell spun off their residential thermostat business several years ago, creating a techi toy company called “Residio.” My daughter had a Honeywell that would no longer do scheduling properly once Residio took over the software.
It's not a dinky transformer, it's that the Nest's battery went dead. A sales decision no doubt, operate it from a rechargeable battery that won't last long because rewiring and additional equipment for the "C" lead would kill sales. Customer thinks it works until it doesn't. That's why most other thermostats use a couple of replaceable AA batteries. But that's so low tech.The nest from what I know is supposed to charge on the boiler off cycle if hooked up 2 wires. His worked for a year and the battery went dead. The primary control on the burner has a dinky transformer so it did not charge the Nest. Operating them on 2 wires doesn't work reliably.
Yeah, OK. Seems to be a top secret what's inside. W, R, B in and W and R out. Of course they don't say what systems it is needed with. Zone valve controllers and power pile come to mind because there is little or no current in the loop to speak of. But other systems certainly should be able to provide the "tiny amount of power" required.you use the Nest power connector if don't the have a common wire. have to check for compatibility . I used it for my neighbors house. About $24.
It didn't work with my son's boiler system. It's not a guarantee.you use the Nest power connector if don't the have a common wire. have to check for compatibility . I used it for my neighbors house. About $24
