JJWalecka
- New England
I thought that I read something regarding the definition of the Neutral conductor. I have searched but to no avail.
A definition that I found is such:
Neutral -The grounded junction point of the legs of a wye circuit. Or, the grounded center point of one coil of a delta transformer secondary. Measuring the phase to neutral voltage of each of the normal three phases will show whether the system is wye or delta. On a wye system, the phase to neutral voltages will be approximately equal and will measure phase to phase voltage divided by 1.73. On a center tapped delta system, one phase to neutral voltage will be significantly higher than the other two. This higher phase is often called the "high leg".
Grounded Conductor - A system or circuit conductor that is intentionally grounded, usually gray or white in color
Technically speaking:
Would it be wrong to refer to the white or gray conductor installed to a device or lighting fixture as the neutral?
Is term neutral pertaining to the grounded conductor?
Thank you,
Justin J. Walecka
Thank you,
Justin J. Walecka
