In the grand scheme of things, it has no voltage but conducts electricity.ronaldrc said:Whats a voltage sink?
That's due to your self-conditioning. :wink:iwire said:I am not seeing your point.
I guess this was my point... arguments like this are bound to be all heat, and no light, for practical training.Smart $ said:In the grand scheme of things, it has no voltage but conducts electricity.
Smart $ said:You have to open your eyes to see.
Pierre.... haven't you ever used Wikipedia? It's perfect for these sorts of tough questions: Neutral wire :roll:Pierre C Belarge said:This thread has headed where I thought it would. There is more to a "neutral/neutral conductor" than just carrying current...
1. When is a grounded conductor a neutral?
2. When is a grounded conductor not a neutral?
3. How does a conductor become a neutral conductor?
The NEC has a couple of new definitions in the '08. Also, the IEEE has definitions. Not that these have changed what a neutral point or neutral conductor is, just that attempts have been made at defining what they are.
Maybe someone can post a couple of the illustrations of the different systems and the relation the "grounded/neutral" has to those systems...
Open a circuit on the neutral side of the load. Which side of the break is energized? ...which is neutral? Will both sides "bite" you or just one?ronaldrc said:If the neutral is not a voltage source how are you going to get a 120 volts?
Seriously though, a nice thread on the topic is here:tallguy said:Pierre.... haven't you ever used Wikipedia? It's perfect for these sorts of tough questions: Neutral wire :roll:
Try that with an ungrounded conductor... will both sides bite you, or just one?Smart $ said:Open a circuit on the neutral side of the load. Which side of the break is energized? ...which is neutral? Will both sides "bite" you or just one?
Another question is:Pierre C Belarge said:This thread has headed where I thought it would...
Answer, assuming you mean the circuit is connected ot two ungrounded conductors: both can "bite" under typical conditions, where grounded items are present and the system is grounded.tallguy said:Try that with an ungrounded conductor... will both sides bite you, or just one?
mivey said:I think most here have learned it, we just like to argue over semantics.:grin:
