- Placerville, CA, USA
- Retired PV System Designer
But by the time you can measure the neutral current it is a little late to change the wire size based on CCC count.I see your problem. My opinion - take the total current of the neutral conductor in question and determine what percentage of it is from non linear loads, but I will consider other approach at this so fire away if you have one.
