A/A Fuel GTX
- WI & AZ
- Electrician
I've been experiencing many situations lately with neutral bars being completely full with no room for additional circuits. I've also seen more and more terminals with two conductors under the screw, usually the grounded and grounding conductor. I would assume that two grounded conductors under one terminal would not be legal. I called Square D tech support and was told that the neutral bar can only have one wire per terminal but the ground bar if present can have two wires per terminal. I'm wondering what some of you out in the field are seeing and doing when you run into full neutral/ground bars? What if you come across a neutral bar that is full in a panel where the neutral has a bonding jumper to the panel enclosure and you add a ground bar, could you land additional neutrals to this ground bar?
