neutral calc question
Re: neutral calc question
Originally posted by eonebrandon:
the neutral was concidered a "current carring conductor
Only sometimes. 310.15(B)(4) covers this issue. Neutrals of 3-wire, single phase and 4-wire, 3 phase systems are not considered current carrying conductors. 3-wire circuits from a 4-wire, 3 phase circuit would be. Watch for non-linear loads. :)
Originally posted by roger: How can a "Neutral" see the same current as any ungrounded conductor. . . ?
If every load on the left side of a panel board was turned on, and every load on the right side was off, then the feeder to that panel would show the same current on the left-hand ungrounded phase and the neutral.
Charlie b
Well, let me first say that in most panels this would have no bearing on the load distrubution on one leg due to the fact most are set up A - B A - B A - B on both sides.
But, I do know what you're pointing out and in this case the grounded conductor would not and could not be considered a "neutral".
So I will stay with my question and point. ;)
Roger
