Wirenut21880
- Yakima, Washington
- Electrician
I've got a scenario that I have been explaining to people and would like to know the code reference:
-There is a 15A 120V lighting circuit that enters box "A" which is a 2g switch box with (2) 3way switches. There are (2) 14/3 romex going to box "B" which is a 2g switch box with (2) 3 way switches. Leaving box "B" are (2) 14/2 switch legs going to separate lights.
-The correct way to make up your neutrals in box "B" is to connect the neutral from each 14/2 switch leg to the neutral in the 14/3 traveler romex and NOT connect all 4 neutral wires together.
Does anyone know where the code specifies this?
