sparks1
- Massachusetts
What happens to the neutral current when it returns back to the power station on the negative half cycle?
Doesn't matter which half, it is returning to the source that generated it.Originally posted by sparks1:
Here is how I suggest you think about electron flow in an AC circuit:ASIDE: To all engineers and purveyors of science who are members of this Forum:
I would like to suggest that we collectively pledge never again to discuss herein the notions of ?drift current,? or ?electron drift,? or ?drift velocity,? or any related subject. They constitute a ?truth? that does not help in the understanding of the daily activities of any electrician, contractor, inspector, instructor, maintenance technician, or engineer. Please consider ?drift? to be a ?graduate level? topic, and the Forum to be an ?undergraduate level? environment.
It does not matter that a single electron might only jump to the next atom, and that a different electron continues down the wire. For all practical purposes, it is the same as saying that a single electron travels throughout the entire circuit at nearly the speed of light. In any event, that is how I intend to respond to questions such as this one.
So I beg that no-one feel himself or herself impelled to point out the liesthat I am about to tell.
Sparks, where do you get this idea? You should say that ALL secondary currents AT ANY TIME are coupled to the primary, and the Poco supplies this reflected current. There is no distinction between positive and negative lobes.Originally posted by sparks1:
Neutral current is magnetically induced back into the primary during the negative half cycle back to the Power Co source.
sparks1 posted February 18, 2005 12:01 PM
If current is transferred through the primary to the secondary of a tranformer in the positive half cycle of the sine wave then the neutral current passes back through the transformer during the negative half cycle of the sine wave.
