But for the electrician level calculation and the "close enough" factor, it works fine.
Roger
In the field, or should I say using field measurements it can deviate from the calculation quite a bit. I've tried using the "basic" formula when trying to determine which neutral belonged to which line conductors at panelboards, where several mwbc come into the enclosure in one conduit and are not grouped. It is not as easy as you might think, for the basic calculation result can be way off when power factors differ.
