maghazadeh
- Campbell CA
I have a code question, please help me with your design and installation
experience.
In the past, most of transfer switches were 3-pole. In a 4-wire system,
there will be three neutral wires present at the ATS, one from normal
source, one from generator and one from load side, how do you connect
these three neutral wires? Do you solidly connect them together? If yes,
when we are connected to normal source there will be a live neutral
going back to off-line generator which is bonded to ground at there.
This means that we have neutral/ground bonding at two different
locations, isn't it code violation? Will it send wrong signal to ground
fault sensor at the normal source service point to cause tripping?
Thanks,
experience.
Thanks,
