topend
- Parma, Ohio
I have a customer who just purchased a residential rental property. It is an up/down double, each suite with a circuit breaker panel in the basement feeding an 8 circuit fusebox inside the suite. Turns out that the 3-wire receptacles throughout the house have the neutral jumped to the grounding terminal. Is it feasible to disconnect these jumpers and install a two-pole GFCI breaker in the basement panels to feed the sub-panels?
Thanks.
Rich Ellis
Thanks.
Rich Ellis
