Shujinko
I am dealing with an existing 480V/3-phase/3-wire electrical system (ungrounded delta). An automatic transfer switch (ATS) is being proposed to be added to this system. The ATS has three phases and an un-switched neutral. Since the existing electrical system is a 3-wire system the neutral branch lugs will not be used.
Is there any requirement in the national electrical code that requires you to use the neutral lugs if they are provided in equipment? Or can you just leave them unused?
Thanks.
Thanks.
