Ctay005
- Orem, Utah, USA
This seems like it should be obvious but I wanted to run this by you guys.
We have a 3 phase high leg delta that were installing 6 single phase inverters on (balanced across the phases). So on these inverters we will be hooking L1 and L2 to 2 of the phases and I wanted to make sure that the neutral hooks up as normal? I was confused on this since hooking L1/L2 across a phase and neutral will give 120 or 208V but hooking the inverter N out to the N on the building is the same as a residential split phase correct? I guess im trying to say, will the neutral on these inverters hook up like normal?
Thanks for the help!
