John Billig
- Wellington, Colorado
I am building a home in Colorado. The power company has installed a transformer and a breaker/meter box next to it. I will be supplying the 200amp breaker at the meter box. I will also run my feeder conduit and wire underground to my 200 amp panel at the home. The panel has a 200 amp breaker. Would the bond from neutral to ground go at the breaker/meter box or in the electrical panel at my home? Assume I would bond the neutral and ground at the panel in my home, but am now questioning if it should go in the Meter/breaker box at the utility transformer which is about 300 ft from my home.
thanks in advance.
John
thanks in advance.
John
