Drod04Mustang
- Avon Park Florida
- Industrial Electrician-Residential Electrician
This is on a RV Trailer that i was working on this weekend for an old lady. I checked with a regular plug in tester and says Hot ground reversed. So RV guy came out and change out a RV plug that had shorted out. I checked out his work and 120 to neutral for both legs, 246 hot to hot and 0 neutral to ground to the RV plug. I changed out the RV cable cause i thought maybe it had melted something in the wire. Now i got the same inside of RV to the wire. But once I connect to the panel the Nuetral to ground bar gives me 120. I tried to narrow it to a certain circuit by taking out neutral one at a time and still no luck. Mind you it was 12v before and they converted it to residential. So couldnt' find it but I am probably gonna take panel out and try small 8 space. and hopefully that will work or for testing pursposes just connect nuetrals and hots to hot legs at the end of the RV plug cable.
