customfab4x4
- Austin, TX
- Engineer
Greetings,
I'm normally working on single phase applications for our contract work but we have a install at our own facility.
Can someone confirm neutral wire sizing?
We are running 480V in Wye configuration using 3 Aluminum conductors sized at 1000 MCM each which runs from a service disconnect to a MLO panel in our main building.
I'm having trouble determining if the neutral needs to be sized the same as the conductor wires. Of course, there is an immense cost associated with it as we are running 400 feet underground. I've researched the topic quite a bit and seem to be getting different answers across the web.
