I have an outdoor power assist door push button that requires 120V. It switches two doors (doors with a motor/switch to control opening/closing) and then goes home. I believe that I need a switch leg, a hot, a neutral, and a ground between the pushbutton and the motors/switches and then a hot/neutral/ground home. A co-worker said I didn't need the neutral wire going from the motor/switch to the outdoor pushbutton. You still get 120V from hot-ground but isn't it safe to run the neutral?
Just an easy question I wanted to clear up.
Thanks
Thanks
