We have a three-phase wye system feeding our plant (480V 277V).
There is one busway in our plant that is a three-wire system (there is no neutral feeding this bus). I recently discovered that there is a lighting panel supplied from this busway that has no neutral. Would it be feasible to run a separate neutral from our main distribution panel, which is approximately 350 ft. from this lighting panel, in conduit and sized for this lighting panel. The lighting panel in question is now using Ground in place of the neutral.
thanks
thanks
