I have a friend who has a 200amp panel in an early 90s' house and he keeps having neutrals burn up at the neutral bar. I checked in the meter base, and all the line side wires in the panel, and nothing is loose. Incoming voltage is correct. It seems to be concentrated to only one of the neutral bars (panel has two). About 6 circuits had discolored insulation and two of the six were severly burnt up. I've been to his house once before, he had a circuit not working and in the panel the neutral for that circuit was burnt at the end. I stripped the wire back and landed it back on the nuetral bar and it worked. Should we start systematically taking the devices out related to those affected circuits? Does anyone have any ideas as to what is causing this? I think it could be in a receptacle where the wires are stabbed into the back of the device. I cleaned up the panel this time, stripped all the bad insulation back, cut the wire ends and reterminated them, we have been watching for a change for about a month, none of the wires are showing a problem.:?
