Most of the load centers I've used come with 1 termination bar on each side of the cabinet, connected by a bonding strap. they are isolated from the cabinet until (if main panel) I install the provided green bonding screw. Since they have a factory bonding strap, it doesn't matter which bar I land grounds or grounded conductors on.
If to be used as a sub-panel, I don't install the green bonding screw and I do install a grounding bar directly to the cabinet. All grounds and neutrals separate.
I believe a wire of sufficient size is acceptable as a jumper if desired if a factory bonding bar is not installed.
