New AFCI diagnostic tool
Oh that's all? Gimme 3 . . .
Actually I think I'll stick with common sense and careful installation techniques like taking the extra second to tuck those bare grounds into the back of the box. (by far the most common Arc fault "problem" I find) :roll:
I was told by the local supplier the cost is approximately $400 - $450.
The tool is not diagnosing the AFCI device, it is diagnosing the branch circuit.
From the Webpage - Intelli-Arc & Overview page
"Diagnosing the cause of AFCI trips can be confusing, but the new Intelli-Arc Diagnostic Tool and the unique trip indicators built into every Siemens AFCI help electricians pinpoint the fault that caused the breaker to trip. The new diagnostic device makes it easier to troubleshoot AFCI circuits by improving troubleshooting accuracy and reducing the number of visits to the problem site. The diagnostic tool can be used with any circuit breaker, regardless of brand.
Currently AFCI protection devices only monitor and protect branch circuits in the home against arc faults. Although the LEDs on the Siemens Combination Type AFCIs can help to point an electrician in the right direction, the AFCIs do not pinpoint the portion of the branch circuit that contained the fault. Arc faults are often intermittent, which can make troubleshooting the branch circuit very difficult. In these cases, it is important to determine whether the fault condition exists in the permanent wiring, the connected equipment or a power cord.
The Siemens Intelli-Arc Diagnostic Tool helps to accurately determine the circuit in which a fault has occurred. When used in conjunction with good troubleshooting techniques, this tool enables the electrical contractor to determine and locate the root cause or source of the fault. The device also provides information including the type and magnitude of the fault. Since the fault may not cause an AFCI to trip for various reasons such as the duration is too short or the current level is too low, the tool provides an indication showing how close an event is to causing an AFCI to trip".
insulated grounds?
insulated grounds?
Do you ever think that NM should have insulated grounding conductors?
