Alelectric04
- Matthew0750!
- Electrician
Ok guys. New home, meter is going to be located about 75ft from the home on the side of another building which is right beside the transformer. It will feed a 200amp panel with pass through lugs which then goes to the home. Inside the panel will be another breaker to feed the building. The 200a main in the panel will act as the emergency disconnect for the home and the building. The ahj has already approved this. I am trying to figure out what cable to run from the panel to the panel inside the home. The panel will be in an interior room under the stairs. Not sure how to actually go about running the cable through the house to the panel since it’s not just on an exterior wall. Since the conductors will technically be fused can I just run them through the attic or drill the studs? Initial plan was to lb into the side of the house but worried about the bend radius of the cable. The house is on a crawl space.
