New NEC 2020 Code question
Sent a copy of what? You sent them the book? That would cost quite a bit.
Yes a copy of the book...cost was about the same as the cost of the book, so I paid double.
It is workable, but comes out with a light gray color because the paper is too thin to prevent the scanner from seeing the back text on the other side of the paper.
I think maybe if you did with a black sheet of paper behind the code page, you might be able to get rid of that gray tint on the finished product.
Why not use a looseleaf version? Wouldn't that be easier to scan?
I would think that if you went to a place with a commercial scanner of some sort that they could load the loose leaf pages into the machine and it could scan the entire book. Maybe such a scanner doesn't exist?
I was not planning on having one scanned, but when I got a second copy for free, I sent it out for destructive scanning....they cut the binding off for scanning purposes. If I would purchase one for that purpose, I would have bought a loose-leaf version
you probably feed it in like a copier but it saves it to pdf. I believe it does both sides at a time.
Many 'copiers' are actually scanners attached to laser printers. So if a 'copier' can auto feed the document it can scan it to a file.
It used to be an actual lens system focusing an image of the document onto a photosensitive surface, but that technique is long gone for basic photocopying.
I bought the loose leaf version and scanned it. I used an HP8710 which is about a $200 all-in-one.
I ran it through the document feeder and had it output as a pdf to a folder on my computer. Then I ran those PDF files through Adobe acrobat OCF and image enhancement to make a searchable copy. Also indexed the whole file.
I ran it through one article at a time to make it easier to group files. Some I had to split up into multiple scans because the HP could only reliably scan about 75 pages at a time without jamming or getting some sort of error.
The whole book scanned is about 142MB after optimizing in Adobe.
This is what it looks like on my phone ….
