Oak
- rochester ny
I'm changing a outside 3 wire/200 amp main disconnect (1986 mobile home-private lot) because I lost half of the breaker due to corrosion. Right now grounding to the panel goes to 2 ground rods 6 feet apart connected to the nuetral bar. 3 wires (2 hot and nuetral) travel underground (conduit from disconnect is only buried 18 inches into the ground) to 200 amp panel in home. My question is do I have to dig down to bring another ground (green) from the outside panel to the inside panel as called for by NEC rules today.
