kwired
Electron manager
- NE Nebraska
Those sections also only apply to a length of conductor that is sole connection to those types of electrodes as well. If you have water pipe electrode and a CEE you could run a T250.66 conductor to the water pipe and the run 4 AWG bonding jumper to go to the CEE. But if you were to run to the CEE first then run to the water pipe you would need a full size from table conductor to the CEE.When 250.66 tells you to. (A) through (C). (A) for rod, pipe and plate electrodes; (B) is for concrete encased electrodes; and (C) is for ground rings. For other electrodes you use table 250.66
250.66 Size of Alternating-Current Grounding Electrode Conductor. The size of the grounding electrode conductor at the service, at each building or structure where supplied by a feeder(s) or branch circuit(s), or at a separately derived system of a grounded or ungrounded ac system shall not be less than given in Table 250.66, except as permitted in 250.66(A) through (C).
Water pipe and building steel are basically about the only things you must run full size in the table to , most everything else can have something smaller than what is in the table as the sole connection to it.
