kwired
Electron manager
- NE Nebraska
- EC
Thats not it works. If you need 166 kva at 240 volts the the amps = 400 amps
You will need to supply 166 kva at 208 volts. 166/(,208 x 1,73) = 461 amps.
OP did not give us 166KVA, he gave us 400 amps @ 240 volts, then wanted to convert to 208 but still supply the same load. Same load will still be 166 KVA but will be higher amps as you said. So is his service still large enough? I don't know what his real load calc is, maybe he will be ok maybe not.
Add: maybe should have said needed to convert to 208, instead of wanted to convert.
