I've got several motors a client wants to add VFD's for. These existing motors are fed from a MCC right now. They are 25 HP, 50 HP, and 60 HP, 480V motors.
The plan is to just intercept the motor circuits at the motor, and install the VFD right at the motor, intercepting the motor branch circuit right at the motor.
I had planned to replace the motor starter buckets at the MCC with new buckets that have standard circuit breakers, instead of starters. However, that's pretty expensive.
Can I just leave the existing starters in place and run the VFD's from those starters? I
'm a little concerned the overloads won't hold if the VFD draws a little extra current for its inefficiency. I've checked, and the breakers in the MCC don't have a thermal trip, just instantaneous. So I don't think I can bypass the overloads.
