bobpaquette
NM between joist bottom and sheet rock
I am noticing a common practice that seems to be largely tolerated of running 12/14 NM under joists in both new conceiled and exposed wiring in garages and housing. This practice puts the wire in the same gap as the sheetrock strapping. Where I am seeing this so commonly....am I missing a interpretation or loophole to 300.4?? Because, drilling and strapping and installing running boards is more time consuming not to mention the compedative disadvantage. I Appreciate your input and Thank You...It means alot to know that I'm not alone out here and can draw from the experience of other professionals.
