NM CABLE
Used Al MC Cable
Meaning the stuff with a PVC coating? I would use conduit and wire. The reason, you can pull the wire out after you are done and use it again. You can use whatever you already have in the shop if you install a large enough conduit. You can use DB120 if you need cheaper and it is stocked.
