NM or UF ?
Re: NM or UF ?
Originally posted by sandsnow:
I'll be forwarding this to the secret email address that blankets all inspectors. Created just for people who think they can get away with this kind of stuff :D
Thanks for the E-mail. I'll be watching for this. :D
[ March 16, 2005, 01:43 PM: Message edited by: ryan_618 ]
Re: NM or UF ?
Now see, this is one big reason I'm not qualified to be an electrician or inspector; I was totally clueless about the mechanical ratings of NM or UF.
Do they have shear and tensile ratings? :confused:
[ March 16, 2005, 01:55 PM: Message edited by: rbalex ]
Re: NM or UF ?
I have been wondering just what happened to people when they had to much code information. Looks like some massive Overcurrent conditions here. Any body know what OCPD needs to be used on this thread. :eek:
Re: NM or UF ?
10-2 works great for pulling vans.UF required if its raining.After the pull you will have a nice piece of 12-2 just use it the next house LOL.Now watch Bob jump me for saying that
Re: NM or UF ?
Another conspiracy. :D
Re: NM or UF ?
Probably more like fault (phase to phase) conditions and damage to forum not rated for the available AIC :eek:
Re: NM or UF ?
We have talked about the residential electricans tying their ladders to the rack with cable but I haven?t learned what to use if I am using single conductor.
Would the conductor have to be ?W? listed or would it need to be a bare conductor in order to ?bond? the ladder to the rack.
Also, would the conductor need to be twisted or could I use a crimp type connector.
All these similes are cute but I think we need to solve this problem as soon as possible.
Re: NM or UF ?
No. Use wire nuts. Makes it easier to remove the ladder.
If said wire nut is UL listed for that size conductor ;) Might have to use a split bolt :roll:
Re: NM or UF ?
If we use wire nuts, do we have to pre-twist? :confused:
Re: NM or UF ?
Since this wiring will be located in areas subject to vehicle travel, it will need to be protected from physical damage.
Re: NM or UF ?
cad weld each time you put the ladder up at the end of the day MMMMMM my puchasing agent would have a fit ;) :p
