Re: NM @ services
hurk: I don't know where those electricians were, but not around me. I forget that I can drive through several east coast states before I can get out of California, it's about 10 and 12 hour trips from my house to the two eastern corners of California. There are a few extremely rural areas that do not have the demand for busy building depaartments.
I don't know if it's true but I heard a builder tell a story about a friend who built in Montana. He went to the building department and after the minimal paperwork, he asked about inspections. They laughed and said, "It's your house, if you don't want to build it well, that's your problem."
Also, i don't understand the difference between being "in" the wall as oppossed to passing through the wall. Isn't a conduit that passes through the wall "in" the wall as well
On a side note relevant to discussion, I have used gutters backed to the panel, nippled, into garages, as a junction box for new services and was never called on it. I have used them outside with Myers hubs in SF area with no problem. Getting all the romex to work with a new panel, often leaves many short, and most inspectors dislike any junctions in panels (40% rule, I think).
Also I am not clear how 230.6 actually is interpreted to disallow feeds, adequately protected, from being in a wall. I could find no other language in the service section that would support that interp, but it wouldn't be the first time I was corrected. Maybe it's in the handbook. I'll look later.
gotta run, paul
