Wonder why the manufacturers spend the money to get them listed?Kind of a touchy subject IMO.
There are ones out there that are listed, and many AHJ's are particular you follow the instructions. Yet at same time code doesn't requrie them to be listed and you can get non listed ones with no such instructions - makes no sense to have to follow such instructions to me if not required to be listed to begin with.
IDK.Wonder why the manufacturers spend the money to get them listed?
Three... The world may never know.What is the maximum number of cables that can be secured with a NM staples?
The "listed ones" I posted a link to have one that says is for four 2 wire cables.Three... The world may never know.![]()
"Mr. Owl . . . "Three... The world may never know.![]()
I like the sharp points on them small nails. really easy to nail inIDK.
Here is the ones I primarily use, they are generally better performing than other brands I have used.
They are listed and instructions state certain cable combinations, and many inspectors here seem to like to pick on those if you don't follow the instructions. I even used the ones for stacking two 2 wire NM cables on MC cables for years, then suddenly started being told they aren't listed for that. Simply stupid IMO. The "stackers keep you from overdriving the staple and smashing the cable, unless you really try, but is ok to use an unlisted wire type staple and easily overdrive it if not really careful.![]()
What is the maximum number of cables that can be secured with a NM staple?
Manufacturer of the ones I use list " used to secure 2 conductor NM or UF type cables to wood".
Nothing stating the number of cables.
Any code language that specifies number of?
Seems someone didn't like the answers they got to the same question back in June!NM staples
If a brand of NM staple doesn’t specify the number of cables you can put under a staple can it be as many as 3? Example : “For securing 14/3. 14/2. and 12/2 NM cables” As opposedforums.mikeholt.com
Do you mean we are replying to a question that has been asked before?Seems someone didn't like the answers they got to the same question back in June!
This time it was the same "asker"!Do you mean we are replying to a question that has been asked before?
Never. Can't be.
I may be guilty of asking the same question multiple times over the years. I blame my brain being fullDo you mean we are replying to a question that has been asked before?
Never. Can't be.
