Re: no bathroom receptacles
Thanks for all the input.......
First of all, I live in Wisconsin.
I called the AHJ and was told I did not need an outlet in the bathrooms according to national, state and local codes, considering that no walls or floors were opened or altered in any way.
But here is the kicker.
After further discussion, I had learned that when the ORIGINAL light fixture was removed and was to be replaced, at that point I was now required to not only add a recep. in the bath, but it had to be up to the 2002 code.
The existing light fixture had a non grounded recep. factory installed in the fixture, which would have been fine, had it remained.
But since it was to be replaced, it was not grandfathered in under the original code when the building was built, therefore the bathroom must comply to the most current codes.
The reason I posted this question in the first place was that the bath outlets were missed in the remodel quote, and there will be excess time and materials to bring the baths up to code.
Thanks all for the info, facts, and comments.
All was appriciated.
By the way, I hold a state master licence for the state of WI, and have been in the practice for 22 years. My only concern with this project has been that it was residential. I have been doing commercial/industrial work for the last 20 some years, and needed some good input before I talked to the local AHJ.
Thanks again all!
Sam77
