busman
- Northern Virginia
- Master Electrician / Electrical Engineer
For residential services in my area, the only way to disconnect all power to the service panel is to pull the meter (no disconnect switch prior to the loadcenter CB) which I expect is very common due to cost. For small tasks (such as adding a single circuit) in the service panel, I have used 4 methods depending on the spaghetti factor, but none seems ideal:
1) Work the panel "hot". No disruption to homeowner, but not the safest.
2) Shut off the main CB. Probably the best since the only hazard is from the lugs.
3) Pull the meter myself. Dangerous and really annoys the PoCo when they find the security tag cut. (My boss used to force me to do this)
4) Have the power company pull the meter. The safest solution, but takes an entire day or more to have it pulled and reinstalled.
Just wondering what others do?
Thanks
Thanks
